hootie119
Jun 24, 2026Aspirant
Help to install Nighthawk ax6 router modem
I have a new Nighthawk AX6 WiFi router modem model cax30. I am having great difficulty getting it up and running. I need help
- Jul 02, 2026
I discovered all I had to do was contact my ISP Xfinity. It took two or three minutes and I finally had the Internet back. I am very pleased with Nighthawk Router/Modem.
Thanks everyone for your helpful comments.
Jun 25, 2026Guru - Experienced User
What difficulties are you running into?
Set up with a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Which ISP are you connecting it with?
Be sure to contact the ISP first to have them get the modem portion of the unit associated with there services first.
hootie119 wrote:I have a new Nighthawk AX6 WiFi router modem model cax30. I am having great difficulty getting it up and running. I need help
