IdiotSavant
Feb 12, 2019Aspirant
Hidden Network Problem
Hello,
I've had a C7000v2 router for a little less than a year now and I've created a problem. I change the IP address, use MAC address filtering, and disable the broadcast of my SSIDs; everyth...
- Feb 21, 2019
Have you tried to rename the SSID Stop the broadcast then manually connect those devices?
DarrenM
DarrenM
Feb 21, 2019Sr. NETGEAR Moderator
DarrenM
- IdiotSavantFeb 23, 2019Aspirant
Thank you for the reply Darren. I didn't try to re-rename the SSID but I did try to manually connect when the broadcst was off with no luck. I ended up giving this router to a friend who doesn't have an issue broadcasting and picking up a new router for myself.
