IdiotSavant
Feb 12, 2019Aspirant
Hidden Network Problem
Hello,
I've had a C7000v2 router for a little less than a year now and I've created a problem. I change the IP address, use MAC address filtering, and disable the broadcast of my SSIDs; everyth...
- Feb 21, 2019
Have you tried to rename the SSID Stop the broadcast then manually connect those devices?
DarrenM
DarrenM
Feb 21, 2019Sr. NETGEAR Moderator
DarrenM
IdiotSavant
Feb 23, 2019Aspirant
Thank you for the reply Darren. I didn't try to re-rename the SSID but I did try to manually connect when the broadcst was off with no luck. I ended up giving this router to a friend who doesn't have an issue broadcasting and picking up a new router for myself.
