Drez_19
Mar 05, 2019Aspirant
High Uncorrectables lower channel
Two xfinity calls and 4 new coaxial cables later I'm still having issues with downstream power ramping up and lowest channel uncorrectables. My DS varies from +5 - +9 and the lowest channel is always ...
DarrenM
Mar 07, 2019Sr. NETGEAR Moderator
Are you getting T3 and T4 timeouts in the logs of the modem?
DarrenM
Drez_19
Mar 08, 2019Aspirant
Wanted to post another update in case you're still monitoring, had another T3 error today and my two lowest DS channels continue to have a 4:1 ratio of Uncorrectables to Correctables:
| 2019-03-08, 18:37:56 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=14:59:c0:5e:cb:a8;CMTS-MAC=00:01:5c:6b:56:67;CM-QOS=1.1;CM-VER=3.0; |
| 2019-03-06, 23:47:43 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=14:59:c0:5e:cb:a8;CMTS-MAC=00:01:5c:6b:56:67;CM-QOS=1.1;CM-VER=3.0; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 1 | 507000000 Hz | 6.1 dBmV | 37.1 dB | 577 | 2799 |
| 2 | Locked | QAM256 | 2 | 513000000 Hz | 5.8 dBmV | 40.3 dB | 443 | 2060 |
