Drez_19
Mar 05, 2019Aspirant
High Uncorrectables lower channel
Two xfinity calls and 4 new coaxial cables later I'm still having issues with downstream power ramping up and lowest channel uncorrectables. My DS varies from +5 - +9 and the lowest channel is always ...
Drez_19
Mar 07, 2019Aspirant
Thank you for replying. I accidently cleared the logs but since yesterday I did have another one. Previously I've had one every other day.
DarrenM
Mar 11, 2019Sr. NETGEAR Moderator
Here is a good article on what those errors mean
https://pickmymodem.com/cable-modem-t3-and-t4-timeouts-error-messages-and-how-to-fix-them/
DarrenM
- Drez_19Apr 06, 2019Aspirant
Posting back with a post-Comcast tech visit. They removed an unnecessary splitter from the main switch/box on the home, power values on each channel are now lower/better but I cannot get rid of the two lowest frequencies that have ever-growing Uncorrectables. Is this still a Comcast/Xfinity signal issue or do I need to dump my CM600 and get a different model? This is causing dropouts/ping spikes during gaming and even streaming video.
Standard setup is CM600 > Orbi RBR40 + 1 RBS20, results are the same with or without Orbi in the mix.Things tested/fixed:
- Running a Ping test directly from Outside Line>Modem>Mac without the router invovled I get random ping spikes as well as Timeouts.
- Ran 4K video stream on Youtube while running Ping and saw Timeouts/Dropped frames in the video (With Settings for Nerds turned on)
- Doing anything extra like Dropbox syncing etc causes ping to jump from 10ms to 500ms or higher, same with Speedtests which actually hit 1200ms and them Timeout.
- Done soft resets, factory resets, and reset through my Xfinity app and the two lowest channels remain with uncorrectables.
After 45min of uptime. Note that these continue to have a 4:1 ratio of higher uncorrectables.
Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 1 507000000 Hz 3.0 dBmV 37.1 dB 27 164 2 Locked QAM256 2 513000000 Hz 2.6 dBmV 40.3 dB 18 97 3 Locked QAM256 3 519000000 Hz 3.0 dBmV 40.5 dB 0 0 4 Locked QAM256 4 525000000 Hz 2.9 dBmV 40.4 dB 0 0 5 Locked QAM256 5 531000000 Hz 2.8 dBmV 40.3 dB 0 0 6 Locked QAM256 6 537000000 Hz 3.2 dBmV 40.5 dB 0 0 7 Locked QAM256 7 543000000 Hz 2.8 dBmV 40.3 dB 0 0 8 Locked QAM256 8 549000000 Hz 3.0 dBmV 40.4 dB 0 0 9 Locked QAM256 9 555000000 Hz 3.4 dBmV 40.5 dB 0 0 10 Locked QAM256 10 561000000 Hz 3.1 dBmV 40.3 dB 0 0 11 Locked QAM256 11 567000000 Hz 3.4 dBmV 40.6 dB 0 0 12 Locked QAM256 12 573000000 Hz 3.6 dBmV 40.6 dB 0 0 13 Locked QAM256 13 579000000 Hz 3.4 dBmV 40.5 dB 0 0 14 Locked QAM256 14 585000000 Hz 3.8 dBmV 40.8 dB 0 0 15 Locked QAM256 15 591000000 Hz 3.7 dBmV 40.7 dB 0 0 16 Locked QAM256 16 597000000 Hz 3.9 dBmV 41.0 dB 0 0 17 Locked QAM256 17 603000000 Hz 4.3 dBmV 42.0 dB 0 0 18 Locked QAM256 18 609000000 Hz 4.2 dBmV 41.9 dB 0 0 19 Locked QAM256 19 615000000 Hz 4.4 dBmV 41.9 dB 0 0 20 Locked QAM256 26 657000000 Hz 4.6 dBmV 42.0 dB 0 0 21 Locked QAM256 28 669000000 Hz 4.5 dBmV 42.0 dB 0 0 22 Locked QAM256 30 681000000 Hz 4.8 dBmV 42.5 dB 0 0 23 Locked QAM256 31 687000000 Hz 4.5 dBmV 42.5 dB 0 0 24 Locked QAM256 32 693000000 Hz 4.8 dBmV 42.5 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 3 5120 Ksym/sec 23000000 Hz 46.3 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 35800000 Hz 45.5 dBmV 3 Locked ATDMA 2 5120 Ksym/sec 29400000 Hz 46.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 16600000 Hz 46.8 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
