Swytch
Jun 01, 2017Aspirant
Hijacked LAN IP
***This issue has already been posted but it is still unanswered*** My router is producing false DDoS in the log but something strange is happening that I don’t understand. When either of my two iPh...
netwrks
Jun 01, 2017Master
Could be something your router (C3000) / ISP dridhas has the same issue with his phone(s). He is also using a C3000.
- dridhasJun 01, 2017Aspirant
im leaning torwards the possibility of a bug on the C3xxx series.
i read somewhere that they replaced the C3000 with a C3700 and happened the same thing.
- SwytchJun 01, 2017Aspirant
I can't imagine it being the router if the LAN IP is unchanged when I'm on a VPN and the VPN only changes the external IP after it leaves the home network...so It only happens when the iphone connects to an external source. The VPN wouldn’t have an effect if the router were assigning the IP to the phone since the VPN only functions after data leaves the modem/router. The LAN IP would chould regardless if it were a router issue.
VPN runs on a different network layer.
as for me, i was able to narrow it down to my iphone due that i reset it to default and upon first connection to activate, the ip was changed within seconds.
- netwrksJun 01, 2017Master
If you are using a VPN, then your IP Address will certainly change to the subnet that is being used by the VPN provider. Once disconnected from the VPN, then your phone's ip should show the router subnet. That's they a VPN connection should work.
- DarrenMJun 13, 2017Sr. NETGEAR Moderator
Hello Swytch
Can I get some more info from you1. A Screenshot of IP address of iPhone.
2. Can you access internet?
3. C3000's backup file when the issue happens.
4. Do you use a VPN?
5. Do you use iTunes or QuickTime app?
6. Can you provide his Network topology?
7. When did issue occur? Is there any change in their iPhone?
8. What is the iPhone model? iOS version? Or can they provide a video (or some pictures) to describe it in the details?
Thanks
DarrenM
