arrrbee
Dec 14, 2015Aspirant
Home Network suggestions
I need some pro advice on what to do with my home network.
I have Xfinity Blast! internet with 150 MBPS internet speeds. I originally bought a Netgear C3000 gateway device. The wireless interne...
Babylon5
Dec 15, 2015NETGEAR Employee Retired
Just to be clear, is your speed issue just wireless or wired also, does a computer which has an Ethernet cable connection to the router have a poor Internet rate?
When you say that Netgear said there was a lot of interference in your area, did they mean that you have a lot of local WiFi networks operating nearby?
Personally I prefer to separate the cable modem from the router (two separate devices), though there’s really no need for that. I have the cable modem close to the incoming cable connection, and I have a number of wireless routers configured as Access Points in various places in the house to give full WiFi coverage, the router (wired only) is near the modem. I use flat Cat6 Ethernet cable which is easily run under skirting board or carpets (not where people will tread on it).
arrrbee
Dec 15, 2015Aspirant
The speed issue is wireless only. When I use a hardwired ethernet cable on my laptop, I get my full internet speeds.
Yes, they said there were a lot of networks in the area.
Honestly, I was a little bit surprised. Again, my apartment has only two bedrooms. I don't think I'm having unrealistic expectations by wanting the wifi signal to cover my whole place...
Any preference between a more powerful wifi router and multiple wifi routers around the house?
- Babylon5Dec 15, 2015NETGEAR Employee Retired
The answer really depends on layout and construction, e.g. brick / reinforced walls will attenuate signals significantly differently to plasterboard walls. Given your description I would suggest a router such as the R7000, simply because I have one and it covers both floors of my house completely (interior brick walls).
