lprobert
Dec 07, 2025Aspirant
How can I purchase a PAV12V25 power adapter?
I can see this adapter on the Netgear website, but I can't see where to purchase one.
CrimpOn
Dec 07, 2025Guru - Experienced User
Search on Amazon. I found several from $12 to $22.
- lprobertDec 07, 2025Aspirant
Amazon was one of the first places I looked. I found plenty of power adapters, but I did not find this exact model.
- StephenBDec 07, 2025Guru - Experienced User
Are you sure the PAV12-100NAS won't work. It has the same specs. Maybe check the compatibility list on Amazon.
I need a power adapter that has the prongs in the same direction as the PAV12V25, i.e., horizontally instead of vertically relative to the body of the adapter. That's so it'll fit on my BackUPS.
