robert_long's avatar
robert_long
Follower
Aug 16, 2016
How do I change the DNS IP addresses ?
I have experienced a security breach at a third-party nameserver and need to change my DNS IP addresses.  Can the DNS IP addresses be changed on the modem, or will I need to change the modem itself ?
(DNS IP addresses are the paired-IP addresses that are often designated as Primary and Secondary).
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello robert_long
    Your modem uses the DNS from your ISP so no way to change the DNS on this modem.
    DarrenM
