DanteYoda
Jul 27, 2019Aspirant
How do i fix this?
Hello i'm having issues with my Antivirus its saying my Netgear D6220 is insecure on HTTP how do i go about fixing this i've checked through the settings and i cannot find a way to fix it.. Is it...
- Jul 28, 2019
Firmware Version
V1.0.0.52_1.0.52I see all i'll get here is condecending attitude.. Thats fine i understand you believe this to be nothing but i for one do not.. And i'm glad useless idiots like you are here to be smart asses to customers.
Netgear lost a customer today forever thanks to a scumbag with no training.. Good luck i hope this company fails i will tell whoever i can never to buy this trash.
Good luck good bye.
DanteYoda
Jul 28, 2019Aspirant
antinode wrote:> [...] how do i go about fixing this [...]
You don't. You could ignore it.
> Is it even possible without an update? [...]
Probably not. "an update" from what?
https://community.netgear.com/t5/x/x/m-p/1726206
Ignore a potantial exploit into my system seems not smart and there has been no firmware updates for my modem since i purchased it.. i'm using the latest..
Its ok this will be the last netgear i ever buy, the software is poor and the support is non existent.. Obviously netgear takes security very lightly, poor company all round.
antinode
Jul 28, 2019Guru
> [...] i'm using the latest..
As always, an actual version number would be more useful than your
opinion of what's "the latest" today.
> Ignore a potantial exploit into my system seems not smart [...]
It's not "a potantial exploit into [your] system"; it's another
(potential) vulnerability if your system is already seriously
compromised. As it says in that cited thread, "If someone can
overlisten to that traffic, then you're already in big trouble."
> [...] Obviously netgear takes security very lightly, [...]
Or, at least, it pays little attention to problems like this, which
present miniscule actual threats, but do disturb many users.
- DanteYodaJul 28, 2019Aspirant
Firmware Version
Good luck good bye.
- antinodeJul 28, 2019Guru
> [...] i understand you believe this to be nothing [...]
I didn't say that it was nothing. Read it again. What I said was:
> [...] Presumably, you're talking to your own gizmo on your own LAN.
> If someone can overlisten to that traffic, then you're already in big
> trouble.Which, I claim, is (still) true.
> [...] i'm glad useless idiots like you are here to be smart asses to
> customers.You're welcome, but I'm not Netgear, you're not my customer, and if
you think that you're dealing with a serious security problem here, then
I don't value your opinion very highly, either, no matter how
eloquently you express it.
