Ann3
Oct 18, 2016Aspirant
How do I turn off WPS?
How do I turn off WPS? Should it be off for security? I don't use it. I tried using the button to turn it off and I tried to find a way in the Netgear Genie. Thanks
DarrenM
Oct 20, 2016Sr. NETGEAR Moderator
Hello Ann3
The WPS settings are in Advanced-Advanced Setup- Wireless settings.
DarrenM
bowtiedoc
Feb 25, 2017Aspirant
I try to keep my SoHo network as secure as possible. I recently read about disabling WPS so I looked for the way to do it. Took a bit of digging but eventually I found you guys. Just a note to say thanks.
Best Regards
the bowtiedoc
