Sonrio224
Oct 10, 2016Aspirant
How do i use my Netgear CM600 Cable Modem?
I have bought this modem to replace my Comcast modem (sort of an upgrade if you will) and, after a while to get the internet working (calling them up and what not), got it to work in a somewhat "okay...
- Oct 12, 2016
Hello sonrio224
The CM600 is just a modem you need a router to put between the switch and the modem to do all the features you are looking for without a router you can not run multiple pcs correctly.
DarrenM
DarrenM
Oct 12, 2016Sr. NETGEAR Moderator
Hello sonrio224
DarrenM
- Sonrio224Oct 12, 2016Aspirant
Thank you so much. it took me awhile but i was able to figure that out and put things together.
Should be able to handle it from here.
