Sonrio224
Oct 10, 2016Aspirant
How do i use my Netgear CM600 Cable Modem?
I have bought this modem to replace my Comcast modem (sort of an upgrade if you will) and, after a while to get the internet working (calling them up and what not), got it to work in a somewhat "okay...
- Oct 12, 2016
Hello sonrio224
The CM600 is just a modem you need a router to put between the switch and the modem to do all the features you are looking for without a router you can not run multiple pcs correctly.
DarrenM
DarrenM
Oct 12, 2016Sr. NETGEAR Moderator
Hello sonrio224
DarrenM
Sonrio224
Oct 12, 2016Aspirant
Thank you so much. it took me awhile but i was able to figure that out and put things together.
Should be able to handle it from here.
