ALovely
Feb 17, 2019Follower
How to access my security key I dont remember it.
I had to put a new hard drive in one of my laptops and when I went to install other programs I could not access wifi because I did not have my security key. How can I get access or reset
DarrenM
Feb 20, 2019Sr. NETGEAR Moderator
If you have any other device connected to the router go to www.routerlogin.net and log in with admin/password and if you never changed the default password. Then you can click Wireless on the left-hand side where you can see your passwords.
DarrenM
