cdysthe
May 07, 2017Virtuoso
How to check firwware version on my CM600?
Hi, My ISP, Comcast, are as I understand it updating my Netgear CM600 modem. But if I would like to see which version of the firmware is running on my modem, how would I be able to do that?
DarrenM
May 08, 2017Sr. NETGEAR Moderator
Hello cdysthe
You should be able to log into the modem by going to 192.168.0.1 then use admin/password to login then in the top right hand corner of the page you should see the FW version.
DarrenM
