milepa76
Apr 02, 2016Follower
How to limit wifi speed for 2.4GHz or Guest WiFi
how to limit wifi speed for others
The "Options wifi 2.4GHz" or Guest wifi
I'd like to make the maximum speed in [Download 1m], [upload 500kb],
How do I this setting?
D Link Routers were using before was possible to speed limits,
But then,,, Netgear can not use speed limit,
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello milepa76
yea unfortunately you can not limit the speeds per connection or device withing netgear genie.
DarrenM
