Falcon1510
Jul 13, 2016Aspirant
How to make a cable modem into a router
Hi, I have recently purchased a second C6300BD-1TLAUS cable modem/router and I am wanting to use it as a router. Can this be done ? if so how do I make this happen both from a wiring perspective and from configuring it on the computer. Thanks.
Unfortunately, the C6300 is not suitable for use only as a router. Return it, purchase a regular Wi-Fi router and connect it to your first C6300. Then log onto your first C6300, go to ADVANCED > Administration > Router Mode and disable Router Mode. This will put it into bridge mode and allow your router to take over.
- Falcon1510Aspirant
Thanks for your quick response.
