ceeteebee's avatar
ceeteebee
Follower
Jan 15, 2016
How to set QoS priority by device and by service on C7000 Modem/Router?
I would like set priority to my VOIP (OOMA) connected to Ethernet port. Don't see anyway in the Genie menu to access QOS although the item does appear on other Nighthawk models.. Appreciate any advi...
  • DarrenM's avatar
    Jan 15, 2016
    Hello ceeteebee
    Qos is not apart of the C7000 if you were looking for this feature you would want to buy a cable modem and use one of the Nighthawk routers like the R7000.
    DarrenM
