rahul8886's avatar
rahul8886
How to use NETGEAR AC1750 with ethernet input
Hello Community,
I have NETGEAR AC1750 which takes coax input. I it possible to use this modem with ethernet input of internet? I am trying to save the cost of buying a new modem to be able to use ethernet input becuase I love this one and have been using it with coax input for a while now.
  • > I have NETGEAR AC1750 [..]
       "AC1750" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "ACxxxx", but that's not the
    model identifier.  Look at the product label.
    > Model: C6300|AC1750 Cable Modem Router Docsis 3.0
       Is that accurate?
    > [...] I it possible to use this modem with ethernet input of internet?
       A C6300 is a modem+router, not only a modem.  It doesn't have an
    Ethernet WAN/Internet port, so you can't use it as a router-only.
    > [...] I am trying to save the cost of buying a new modem [...]
       "a new modem" or "a new router"?
    > [...] to be able to use ethernet input becuase I love this one and
       But it doesn't have an "ethernet input".  To what would you connect
    its Ethernet WAN/Internet port if it had one?
       You might want to look at other Netgear routers whose model numbers
    begin with "R".
       It may be possible to use a C6300 as a wireless access point, not as
    a full-function router:
          https://community.netgear.com/t5/x/x/m-p/1463500
    • C6300|AC1750 Cable Modem Router Docsis 3.0 - Yes this is accurate.
      My ISP provides ethernet as input so my simple question is, can I somehow use C6300|AC1750 Cable Modem Router Docsis 3.0 with ethernet inout instead of a coax input. May be a converter?
      • > [...] can I somehow use C6300|AC1750 Cable Modem Router Docsis 3.0
        > with ethernet inout instead of a coax input. [...]
           Still true.
        > [...] May be a converter?
           I don't know of one.
