japublications
Jul 16, 2016Aspirant
How to use the r6100 as a router connected to a C3700 modem/router
Hello - I have a Xfinity 150 meg per second internet package. I bought a C3700 modem router combo and used it for a few months. Being that we have over 20 devices connected to it, I wanted a simul...
- Jul 25, 2016
Hello japublications
Did you set your R6100 up as a access point if so that may be why it does not work when you make the c3700 a modem only.
DarrenM
japublications
Jul 22, 2016Aspirant
Thank you for the reply. When I logged into the c3700 and turned off router mode, my connection not longer worked. I was able to connect to the r6100 SSID, but there was only local addresses in the configuration meaning nothing was being transmitted from Comcast. Turn it back on and everything works again. Keep in mind, the 2.4 and 5.2 channel lights went off on the c3700 from the time I started broadcasting the SSID via the r6100.
- DarrenMJul 25, 2016Sr. NETGEAR Moderator
DarrenM
