mattp0807's avatar
mattp0807
Huge ping spikes wired and wireless
Hello, after fighting with my IPS MediaCom I have been experiencing so many issues with my internet spiking from 20ms ping to 250ms randomly and in a constant manner an example of pings ive experienced through ping google through command prompt using (ping www.google.com -t) are
time= 19ms
time= 17ms
time= 47ms
time= 55 ms
time= 241ms
time= 171ms
request timed out
request timed out
time= 18 ms
time= 181ms
time= 170ms
time= 250ms
time= 18ms
and so on.
I am through a wired connection, my ips has come around 12 times to my house to fix the splitter, lines, and tap and they have ruled it as a router/modem issue.
My support contract is up and i do not want to pay $81 for a one time fix.
  • plemans's avatar
    What you could try if they're saying it isn't the modem is to have mediacom put in their own modem and rent if for a month. Then check speeds/pings. If you continue to have spikes, its still the line and they can't blame your device.
    If they resolve, then it could be your device.
    • mattp0807's avatar
      mattp0807
      ive had the same modem at my college house and it worked fine but about three months into using it at my parents house it started having problems. I called netgear and they said i need to "configure it" with their technitian but thats just scam to get me to buy the insurance.
