menchod
Aug 04, 2022Follower
Hughesnet Provider
I did some research on Hughesnet alternate modems. The results indicated that the AC1900v was compatible the the Hughesnet service. I would like to get some inside knowledge on the compatibility, if...
Aug 04, 2022Guru - Experienced User
AC1900 is not a model #. Need a model# here.
I recommend contacting the ISP to see if they support users owned modems on there network. They will have this information.
