menchod
Aug 04, 2022Follower
Hughesnet Provider
  I did some research on Hughesnet alternate modems. The results indicated that the AC1900v was compatible the the Hughesnet service. I would like to get some inside knowledge on the compatibility, if...
Aug 05, 2022Guru - Experienced User
Hughesnet is a satellite internet provider. You need to use one of their gateways but then you can connect a different router/access point to it. Keep in mind, it isn't going to increase your internet speed but it might provide better coverage.
