Tnguyen93's avatar
Tnguyen93
I’m experiencing the same thing with my CAX30
I’m experiencing the same thing with my CA30 bought a year ago. It won’t even boardcast wifi can’t see wifi in any device, tried ethernet cable from modem to pc but it won’t work. Tested with old modem wifi + ethernet cable work fine. Just completely dead modem now.
  • Ethernet port is dead, can’t login to modem how can I downgrade the firmware
    • FURRYe38's avatar
      All ports dead? Try other ports and swap LAN cables.
      Try a factory reset and setup from scratch.
      Do you have wifi connection with the modem? You can send the FW update over wifi if you can connect that way.
      • Tnguyen93's avatar
        Tnguyen93
        No wifi all port dead, no way to get access to the modem
