netgear_boston
Jul 31, 2025Follower
I cannot login routerlogin.net
I have a simillar problem on cax 30 with latest firmaware. I cannot login routerlogin.net. When after attempting hundreds of login attempts I can get in. Once i get in if i try to make some changes, ...
Jul 31, 2025Guru - Experienced User
Can you log in to 192.168.1.1 or 192.168.100.1?
Has a factory reset and set up from scratch been performed since last FW update?
What version of firmware is loaded on the modem?
What browser are you using? Happens with MS Edge or Firefox?
WIreless or ethernet connected?
Which ISP are you connected with?
