jamesfong
Jun 22, 2026Aspirant
I have a Netgear CAX30 wifi cable modem router. Reset button does not reset the admin password.
I try the reset through 3 time failed passowd input, with device SN typed in , but my security questions's answer seems not right.
I used the paper clipper pin to hold the reset botton for more than 15 sec, but after the modem online again. on routerlogin.net page, I typed passord for admin, it still shows the passord is wrong for admin.
any further sugeestions to reset the password for admin?
Thanks
James
Try disconnecting the ISP Coax cable from the CAX30. Then press the reset button for 15 seconds then release.
If you see the front LEDS turn OFF then cycle thru, reconnect the ISP coax cable and setup the modem with a web browser at 192.168.1.1
- jamesfongAspirant
Thanks, it works now.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
