ThomasCruise100
Jul 23, 2025Tutor
I think we have the same underlying issue
I think we have the same underlying issue. I tried messing with netgear support last year. All they ever do is "go to settings and check/uncheck this box" then wait and see if it's fixed. Did that ab...
ThomasCruise100
Jul 24, 2025Tutor
The CAX80 is buggy as s***. Clearly there's a widespread problem as multiple people are having the same issue. Let me know if Netgear rolls out a fix. AI suggests the only fix is switching to 2.4ghz band or using ethernet if possible. Disabling AX setting on the router can also help apparently.
