JonnyCl
Sep 06, 2020Aspirant
Icmp attacks please help
[DoS attack] ICMP Flood from This message pops up in my new modem/router about every 20-30 seconds and my isp doesn't know what to do. I was having internet problems the other night and when I chec...
Sep 06, 2020Guru - Experienced User
Have the ISP change the WAN IP address. Usually powering this off for 1 minute or more can change this.
Factory reset the modem and setup from scratch as well.
You might change the wifi password your using as well to see if this maybe coming from the LAN side too.
- JonnyClSep 06, 2020AspirantThank you for taking the time to reply. I have done those things mentioned and the flood still happens. I had the new modem/router setup without any devices on it and it was still being attacked within 3 minutes. I have since had the ip changed and the attacks are still happening. All of the settings are set to default with no port forwarding added
