Answerplease
Oct 21, 2016Aspirant
If you have TWC they disable hard reset
After having horrendous problems for months, and not being able to reset my CMD31T modem ( I called TWC multiple times and had smoke blown up my backside), I was forced to buy an AC1750... Curio...
DarrenM
Oct 24, 2016Sr. NETGEAR Moderator
Hello Answerplease
All the cable companies receive the firmware from Netgear then they review and make any changes they feel necessary and then push it out to the customers.
http://kb.netgear.com/app/answers/detail/a_id/25477
DarrenM
Stealth61
Jan 19, 2017Aspirant
I have a Netgear Cable Modem CM600.
I switched from TWC to WOW internet.
The WOW tech was unable to get my CM600 working because he stated TWC installed firmware on my CM600, which is IPV6. He said WOW uses IPV4. He attempted to use the factory reset button on the back of the modem and it wiped everything but the IPV6 off. He was unable to get the modem working because he did not know how to remove/reset the firmware.
HOW DO YOU RESET THE FIRMWARE so I can use my cable modem with IPV4?
Thanks
- DarrenMJan 23, 2017Sr. NETGEAR Moderator
Hello Stealth61
You can not reset the firmware as it is pushed out by the ISP.
DarrenM
- TsauderApr 18, 2017Aspirant
I have the same problem. You're telling me its impossible to switch internet providers without throwing away my brand new modem/router combo?
- DarrenMApr 20, 2017Sr. NETGEAR Moderator
Hello Tsauder
Are you saying you switched internet providers and your modem is not working? what modem do you have?
DarrenM
