mjalaal's avatar
mjalaal
im tired of this [DoS attack: Ping Of Death]
I get hundreds of these logs in my router, when this happens, the speed drops from 30mb to 400kb or less, please help im not enjoing the internet anymore
I traced the problem it it's coming from the ipad , I did the following
Uninstall all apps
reboot
reset factory
all didnt work, once i connect, i get the same attack and internet drops, I was readying on the forum, they all said they replaced the netgear to silve the problem, do i really need to do so?
[DoS attack: Teardrop or derivative] from 128.2.88.0, port 0
[DoS attack: Ping Of Death] from 128.2.88.0, port 0
  • FURRYe38's avatar
    Contact your ISP and have them help you block thsi IP. Have them also change your WAN IP address.
    Uninstall all apps
    reboot
    reset factory
    • mjalaal's avatar
      mjalaal
      I have this problem since 3 months now, I did contact them over 10 times, I have no idea what to do , but when i browsed the forum I found that several compains about the same exact essue between apple device and the netgear ... read this
      https://community.netgear.com/t5/Cable-Modems-Routers/NETGEAR-C3700-allowing-a-Denial-of-Service-attack/m-p/1245055#M7531
      I almost did everything I can:
      factory reset the iPad
      factory reset the netgear
      changed passwords
      format iPad
      change WAN password and connect only iPad ( DoS attak appear in a few seconds, kills internet )
      changed WAN Password and connect all devices except iPad ( internet works fine )
      should I gave up and just buy motorolla ?
      • FURRYe38's avatar
        Probably. I would get in to a stand alone modem something like a MB7420, then connect up a external wifi router.
        Good Luck.
