Torup
Jun 26, 2017Aspirant
Important Security Update from NETGEAR, June 21, 2017
Hello, On June 21, I received a message in the name of NETGEAR Security asking me to do a Security updating. Before following the instructions and executing the urging, I want to be ABSOLUTE...
DarrenM
Jun 28, 2017Sr. NETGEAR Moderator
Hello Torup
Yes Netgear did send a email to customers about making sure to update your firmware. If you have a cable modem you can not do this manually the firmware will be updated automatically through your ISP.
DarrenM
Torup
Jun 29, 2017Aspirant
Thank you for your answer. So if I have a wireless network I can and should do it?
