BobK123
Feb 20, 2025Aspirant
Intermittent internet connection on some devices
I couldn't find this exact problem after searching the community. I have a C7000 modem/router installed about 2 months ago. I have three devices hardwired to it, and run a wifi network for the rest o...
- Mar 04, 2025
You can do the router side of the CAX80, the ISP, if they support it, may update the modem side as they would be responsible for the mode side.
Feb 21, 2025Guru - Experienced User
How is the wifi configured on the modem?
What channels are being used?
What is the size of the home?
Any wifi features enabled or disabled on the modem? Like Smart Connect?
