BobK123
Feb 20, 2025Aspirant
Intermittent internet connection on some devices
I couldn't find this exact problem after searching the community. I have a C7000 modem/router installed about 2 months ago. I have three devices hardwired to it, and run a wifi network for the rest o...
- Mar 04, 2025
You can do the router side of the CAX80, the ISP, if they support it, may update the modem side as they would be responsible for the mode side.
Mar 04, 2025Guru - Experienced User
The CAX80 is a more capable and more up to date and newer generation gateway system. I'd remove the C series gateway and get with the ISP to help you install the CAX80.
BobK123
Mar 04, 2025Aspirant
Thanks. I didn't realize the CAX80 was the better model. Mine is so old I'll probably need to do a firmware update. Do I do that or does the ISP do it?
Thanks again for the quick response
- FURRYe38Mar 04, 2025Guru - Experienced User
