ButterSquatch
Jul 23, 2022Aspirant
Internet dropping, logs say dos attack icmp flood from different ips (C6300v2)
Hello, I have been having this issue for about two weeks now. My wireless devices will randomly drop connection and when I'm on my desktop (wired) I get lag and or bad packet loss also randomly. es...
Jul 23, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
- ButterSquatchJul 23, 2022Aspirant
not sure which one is the connection status screen but all the things say they are green and connected. Ill attach what I think you are asking about. Just let me know if its not the right thing.
Thank you for the reply!
Also have notice there is more ICMP flood attacks in the logs more from amazon and again some from other places around the world. could my Alexa's be causing this?
- ButterSquatchJul 24, 2022Aspirant
Checked the cable connection again tonight and this is what it is showing. I'm still getting drops in service and those ICMP flood dos attacks are still happening from random IP addresses.
Ill attach screen caps of both.
- FURRYe38Jul 25, 2022Guru - Experienced User
You have come correct and un-correctables that should be Zeros. Check and make sure all fittings are snug, no kinks in the cable line up to the modem. Be sure your using good quality RG6 coax cabling. Remove any coax line splitters.
The power is TOO high. ISP needs to turn the power down:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
Lots of Criticals that the ISP needs to look at as well. Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
