mailmichael
Sep 15, 2014Aspirant
Invalid Data. Lan IP Address Overlapped! - N300 / C3000
Hi, I'm trying to do the very simple task of changing my router's network address, but I keep getting the error "Invalid Data. Lan IP Address Overlapped!". Overlapped with what? It won't tell me....
mailmichael
> Which address are you trying to change?
The network address of the LAN which AFAIK is done by changing the router's IP address on the LAN in "LAN Setup" -> "LAN TCP/IP Setup" -> "IP Address". This automatically updates the DHCP starting and ending IP addresses to match.
> What address does it have now and what are you trying to change it to?
I'm trying to change The router's default IP address from 192.168.0.1 to 192.168.1.1.
After I hit apply, I get the error.
