mailmichael
Sep 15, 2014Aspirant
Invalid Data. Lan IP Address Overlapped! - N300 / C3000
Hi, I'm trying to do the very simple task of changing my router's network address, but I keep getting the error "Invalid Data. Lan IP Address Overlapped!". Overlapped with what? It won't tell me....
fordem
Feb 17, 2015Mentor
It's only a limitation in your mind - you have TWO options - change the guest network, OR, and I think this is the better one - change the network schema you're using.
Avoid using the following ranges - 192.168.0.1, 192.168.1.1, 192.168.10.1, 192.168.15.1 - those are the most commonly used ranges and when you start using VPNs sooner or later you'll discover that the network you're on conflicts with the one back home.
