dridhas
May 31, 2017Aspirant
IP address on phone changing from 192 to 136
hello all, i hope this finds you well. ive been having some issues for the past couple of days on my router and i hope you can give me an insight on what could be the cause. i have 2 io...
dridhas
The iphone connects to the home SSID (2.4Ghz) getting a 192 address on the router and after a few moments that 192 ip address changes to 136 on the same SSID.
if i go to the settings on the phone, i can see that the ip address is still a 192.
ive tried doing a reset to default on the router and on the phone having the same results.
dridhas
Just wanted to post an update on this.
i just reset to factory the iphone and upon connecting to the wifi ssid it immidiately changed it from 192 to a 136.
there is something off with the router
- netwrksJun 01, 2017Master
Reset your router to factory default and reconfigure. You may want to re-flash the router's firmware also. Find your router's documentation here.
- dridhasJun 01, 2017Aspirant
this cant be done on the router due that there is no option inside the menu and there is no firmware to download on the website.
its a C3000-100NAS
Looks like you aren't the only one with the 136.x problem.
https://community.netgear.com/t5/Cable-Modems-Routers/Hijacked-LAN-IP/m-p/1294777#M8648
