strykerzr350's avatar
Jun 19, 2025
Is the Netgear CM2000 end of life now?
Just a question if the Netgear CM2000 is EOL now? I am only using it right now as I dont know when Xfinity will roll out mid split. Once they get it going in my neighborhood I will get the CM3000. ...
  • plemans's avatar
    Jun 19, 2025
    I wouldn't. The CM2050V has been over a year and just starting to get their update rolled out. And that was supposed to be over a year ago. I haven't heard/seen anything about the CM2000. Its unfortunate. I have both the cm2000 and cm3000 and wish the cm2000 would have gotten the update because the hardware is there to support mid-split. but recertification costs $ and they don't invest more in something like that sadly. None of the modem manufacturers do. The Arris S33 and S33v2 is in the same boat
