Gholt
Mar 08, 2024Follower
Is there a way to get telephone (voice service) a using NetGear Nighthawk CM1100?
I bought a NetGear Nighthawk CM1100 to replace an old Ubee cable modem & router combo provided by Spectrum. I did not realize before buying that the Nighthawk is " not compatible with Cable bundled v...
Mar 08, 2024Guru - Experienced User
The CM1100 never had the hardware for phone support. The CM1150v does. Also the CM2050v does as well.
