OfficialFBomb
Mar 07, 2017Aspirant
Issues with my first netgear product..
Well first things first, the gear genie app sucks.. So when logging into via browser and apptemting to change setting i get WPS in progress attemp the changes later BS?? What the hell does that mean....
VE6CGX
Mar 09, 2017Master
What is the model no. of the router? Is it working connected to you ISP? There is no rush for f/w update. First make sure all is working well
before updating f/w. You can do it from router itself, or manually downloading the f/w and do it. Mentioning WPS you must on wireless
connection? It is not a good idea doing f/w update using wireless connection. LAN connection is safer for that.
OfficialFBomb
Mar 21, 2017Aspirant
It is working connected to the isp, the issue is it works worse then the stock model they stick you with, there is no option to update via the router, and the reason i mention wps is when i try and change setting in the routher it usually gives me and error about the wps and to try again later even though im not messing with the wps settings..
