rewolf4
Dec 05, 2016Aspirant
Just purchased model CG3000DV2. Internet working on my computer, but I cannot connect more devices
My compputer is working with the modem/router and I have internet access. Cannot connect cell phone, Amazon Fire tablet and Echo Dot. Keep getting "authentication error" message on each device.
DarrenM
Dec 07, 2016Sr. NETGEAR Moderator
Hello rewolf4
Have you gone into the wifi settings and changed the SSID the security type to WPA2 and the password?
DarrenM
rewolf4
Dec 13, 2016Aspirant
I have changed the password and the SSID. Am still getting "Authentication Error" on all three devices. Computer works fine.
- DarrenMDec 15, 2016Sr. NETGEAR Moderator
Hello rewolf4
I would try to factory reset the modem and setup the wireless. Also did you have a router before the CG3000DV2 and are using the same SSID if so you may need to go to your devices and tell them to forget the network and reconnect.
DarrenM- rewolf4Dec 15, 2016Aspirant
I thought that might be the case, I travel between AZ and CA. I have a separate modem/router combo in AZ and an all in one modem/router in CA which I just purchased. The three devices work in AZ but not in CA. I use Cox in both places. If I reprogram the CA modem/router and carry it back & forth, will that work? Thanks
rewolf4
- DarrenMDec 19, 2016Sr. NETGEAR Moderator
Hello rewolf4
That would only work if your ISP has the modem registered to work on both your accounts if you are fine with calling them to do that when going back and forth than yest it would work.DarrenM
