jillbee
Dec 04, 2015Follower
kaspersky says my network is not secured AND unable to access router login
I had no problem installing and setting up my Netgear C6300. I was able to set up a new login password and I changed the name and passphrase for each channel and everything seemed to be fine. Then I...
George73
Dec 08, 2015Aspirant
I have C3700 & also a Kaspersky software which throws a similar message that my network is not secured. I have no solution on this.
DarrenM
Dec 08, 2015Sr. NETGEAR Moderator
Hello jilbee
Make sure your connected via ethernet and try 192.168.1.1 or 192.168.0.1 see if you can then log in agian. If not you will want to do a factory reset on the modem and try to log in again.
DarrenM
