JudasGoat
Jun 18, 2021Tutor
Keep losing speed
I have a AC2700 CAX30 wifi cable modem router from Costco and 1gb xfinity plan. When I factory reset I get 600-860mbps over wifi 5GHz. Within a couple of hours this drop to 115-225mbps and stays there, no matter what time of day or how many devices are using wifi.
All software is up to date.
Are you using smart connect?
Smart connect allows devices to move between 2.4ghz and 5ghz as needed.
And 2.4ghz is much slower than 5ghz
- I am not using smart connect. Both my iPhone and my laptop are connected to 5GHz
when the speed drops, what do you get over a wired connection?
