Ralo14's avatar
Ralo14
Tutor
Apr 09, 2021
Lag when gaming
I just recently replaced my old modem with a CM700. I have had the R7000 for a while and it runs with zero issues beside needing a reset recently to pick back up Wifi speed. Now when I am playing games online I am experiencing some lag/rubberbanding. Could there be any settings that should be adjusted for the modem?
  • plemans's avatar
    there's not any settings to change on the modem.
    do you experience the same lag/issues if your gaming system is directly connected to the modem?
    • Ralo14's avatar
      Ralo14
      Tutor
      I am not in a location where that is possible but I built this PC months ago and never had any issues gaming on it. I am fairly close to my router (R7000). This is a new issue that just started. When I have my ping visible in game it will spike from 30-40 to 1000. When I ping test my router in Windows 10 everything looks fine. When I ping test Google DNS server I get occasional errors for request timed out.
      • Ralo14's avatar
        Ralo14
        Tutor
        I just realized there is a typo in the OP. The modem is a CM600. Hooked directly to the modem and running a ping test in terminal on my Macbook gives me bad results also. I have normal ping for a bit then it drops for 3-4 seconds and comes back. Xfinity claims everything looks fine on their side.
