Jax2_0
Feb 06, 2017Aspirant
Lan configuration options c7000 modem/wifi router
I jave the c7000 nighthawk modem with wifi router and would like to use it as a modem to connect my tv connected to ethernet port on modem as a peripheral device (screen mirroring ) while using my pho...
DarrenM
Feb 08, 2017Sr. NETGEAR Moderator
Hello Jax2_0
You should be able to connect your smart TV using the Ethernet if you are using the C7000 as your main router. Do you have another router in the mix or not?
DarrenM
