Tee13's avatar
Tee13
Life span of C7000??
Any idea on lifespan of this unit? I am at 2 years 3 months and it is starting to cut out, meaning loss of wireless. Power cycling helps now and then. About ready to replace it. Is the Version 2 better. Help and advice appreciated by this newby.
Thanks!
  • FURRYe38's avatar
    Have you factory reset the modem and set it up from scratch?
    Try placing a USB laptop cooler under the modem to keep it cooler.
    • Tee13's avatar
      Tee13
      As I may have said, Newby here. Where are direction or instructions on how to do some of those things?
      Thanks
