cmueller
Oct 06, 2017Follower
Locked out after Nighthawk firmware update
I updated, but now I can't "see" the modem. Totally locked out. I'm on Comcast and using my NH7000 as a hub. The internet signal is taken from my Comcast box (radios off) and sent to the NH. My ...
Hammerhead11111
Oct 06, 2017Tutor
Thats not waht I was told. While holding in the rest button then power on ur router lights will blink. It worked for me. I did a lot of research on this problem. My router had a blinking greeen power light. This indicates a curupt firmware issue. I found a fix this is what I did.
change ipv4 ip use the following ip 192.168.1.2
download tftp2
Enter 198.162.1.1 for server
pasword for router =password
Browse to ur path where the firmware u want to use is located.
Click update.
I was able to do this and fix my wndr4500. Im I happy I had to do extra work to fix this not at all.
michaelkenward
Oct 06, 2017Guru - Experienced User
I don't know who told you that. It was wrong.
That's a different rest regime.
The tftp thing is also something else.
But, as I said, I find it hard to understand what the heck you are saying.
I urge anyone else reading this discussion to do a bit of research before going down this confusing path.
- Hammerhead11111Oct 06, 2017Tutor
If you cant understand english get some edumacation lamo.
This is easy to understand... If ur router is bricked from this firmware update using the procedure I posted will not make it worse. U can figure it it. I did my part,
