Retired_Member's avatar
Retired_Member
Nov 04, 2017
Log into unknown router
Hi, I purchased a modem second hand. Trying to identitfy the WiFi so that I can login and change the WiFi name and password.
It doesn't show under the original name (NETGEAR63). Is there a unique address I could use to login to this speicifc router?
The MacBook doesn't have an ethernet jack.
Thanks
Robert
  • > [...] It doesn't show under the original name (NETGEAR63). [...]
       Did you do a full ("factory") reset?  That should restore the
    settings to the ones shown on the label.  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  The User Manual explains the procedure.  Look for
    "Factory Default Settings".
    • Retired_Member's avatar
      Retired_Member
      Yes, I did a factory reset, but it still didn't show up as NETGEAR63.
