mdd282s
Jan 30, 2019Follower
Looking for a Netgear Modem Router Recommendation
I am in the market for a DOCSIS 3.0 modem which is capable of at least 8 channel bonding. I also want it to have strong parental controls that can be managed at the MAC address. And also, be able to track usage, daily, by MAC address so I can see which one of my grandchildren are excessive users. It would also be great to control the bandwidth flow by device. You know, give the Living Room TV more bandwidth for Netflix and less to my granddaughter on Roblox. So recommendations please? THANK YOU!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello mdd282s
If you are looking for a modem then you would want either the CM600 or CM700 and you will need to attach one of the routers below in order to get the parental controls that you are looking for
I suggest ones of these routers they are all capable of using Disney circle which will provide the parental controls that you need.
https://www.netgear.com/landings/circle/default.aspx
- R6900
- R6900P
- R7000
- R7000P
- R7900
- R8000
DarrenM
