pricear
Oct 07, 2019Aspirant
Looking for compatible wired router or how to make the current one work!
Hi - I'm interested in getting a wired (non-wifi) router that will not degrade my high speed internet signal from Xfinity (Pittsburgh) and that is compatible with my CM1000 modem. I purchased an inex...
- Oct 07, 2019
Not sure if NG has any wired only routers anymore. They mostly make routers with WiFi.
I now that Ubiquity has wired only routers. You might look into the Edge Router X.
Oct 07, 2019Guru - Experienced User
Most any NetGear router will work with the CM1000. Most any non NetGear router should work as well.
https://www.netgear.com/home/products/networking/wifi-routers/
Do you get good streaming when directly connected to the CM modem with a wired PC?
pricear
Yes, it worked great without the router. The trick is that I don't want a wifi router. I don't want the additional expense of that feature and I don't want the wifi functionality.
Thoughts?
- FURRYe38Oct 07, 2019Guru - Experienced User
